ATaryanik
Сообщение ATaryanik » 2015-04-07 9:48:38
вот из дебагера, так понимаю таблицы не хватает?
[08:39:36.76][45460] [MySQL->Query]: UPDATE `Users` SET `EnterDate` = '1428385176',`EnterIP` = '31.200.199.91' WHERE `ID` = 100
[08:39:36.83][45460] [MySQL->Query]: SELECT * FROM `Permissions` WHERE ('/Administrator/' LIKE `Name`) ORDER BY `Metric`
[08:39:36.83][45460] Load file: '/var/www/clients/client2/web2/web/billing/hosts/root/comp/Formats/Explode/Logic.comp.php'
[08:39:36.84][45460] Load file: '/var/www/clients/client2/web2/web/billing/hosts/root/comp/Formats/Explode/Logic.comp.php'
[08:39:36.84][45460] [MySQL->Query]: SELECT `ID`,`GroupID` FROM `Users` WHERE `ID` = 100
[08:39:36.85][45460] [MySQL->Query]: SELECT `ID`,`GroupID`,`OwnerID`,`IsManaged` FROM `Users` WHERE `ID` = 1
[08:39:36.85][45460] Load file: '/var/www/clients/client2/web2/web/billing/hosts/root/comp/Formats/Explode/Logic.comp.php'
[08:39:36.86][45460] Load file: '/var/www/clients/client2/web2/web/billing/hosts/billing/comp/www/API/Events.comp.php'
[08:39:36.86][45460] [System_Load]: компонент системы (/var/www/clients/client2/web2/web/billing/hosts/billing/system/modules/Authorisation.mod) был загружен
[08:39:36.86][45460] [APCCache::get]: не удалось извлечь объект [key=8804d249754464c10bda8fd0a5fa024c]
[08:39:36.86][45460] [APCCache::get]: не удалось извлечь объект [key=a2c8e6ed8ff34680116f2f27491e0cfe]
[08:39:36.87][45460] [MySQL->Query]: SELECT `ID`,`Text`,(SELECT CONCAT(FROM_UNIXTIME(`CreateDate`,'%Y-%m-%d / %H:%i:%s / '),`Email`,' / ',`Name`) FROM `Users` WHERE `Users`.`ID` = `Events`.`UserID`) AS `UserInfo`,`PriorityID` FROM `Events` WHERE (UNIX_TIMESTAMP() - 10 <= `CreateDate`) ORDER BY `ID`
[08:39:36.87][45460] [Exception]: [ROWS_NOT_FOUND]=(Записи не найдены)
[08:39:36.87][45460] [JBs core]: система работала: 0.24904298782349
[08:39:36.87][45460] [JBs core]: время работы MySQL: 0.07879638671875 [31.64%]
[08:39:36.87][45460] [JBs core]: запросов к MySQL: 12
[08:39:36.87][45460] [JBs core]: загружено компонентов: 8
Сообщение Alex Keda » 2015-04-07 10:02:44
ls -al /var/www/clients/client2/web2/web/billing/hosts/billing.hosting46.ru/tmp/TaskLastExecute.txt
Отправлено спустя 1 минуту 12 секунд:
ATaryanik писал(а):вот из дебагера, так понимаю таблицы не хватает?
настройте отсылку ошибок на почту.
это вообще не ошибка. это выборка событий.
ATaryanik
Сообщение ATaryanik » 2015-04-07 10:44:25
К сожалению на сервере почта вся отключена по причине того что мой IP в СБЛ, только если как то можно через яндекс.
 -rw------- 1 root root 14 Apr  7 09:01 /var/www/clients/client2/web2/web/billing/hosts/billing.hosting46.ru/tmp/TaskLastExecute.txt
-bash: -rw-------: command not found
root@hosting46:~#
root@hosting46:~# ls -al /var/www/clients/client2/web2/web/billing/hosts/billing.hosting46.ru/
total 24
drwxr-xr-x 5 www-data www-data 4096 Apr  6 21:41 .
drwxrwxrwx 6 root     root     4096 Apr  6 21:25 ..
drwxr-xr-x 2 www-data www-data 4096 Apr  6 21:25 config
drwx------ 3 www-data www-data 4096 Apr  6 21:41 files
-rw-r--r-- 1 www-data www-data   72 Apr  6 21:25 host.ini
drwxrwxrwx 7 www-data www-data 4096 Apr  7 09:01 tmp
Отправлено спустя 34 минуты 8 секунд:
Вот еще
#0 /var/www/clients/client2/web2/web/billing/hosts/hosting/system/libs/ISPConfig.php(122): SoapClient->__call('login', Array)
#1 /var/www/clients/client2/web2/web/billing/hosts/hosting/system/libs/ISPConfig.php(122): SoapClient->login('admin', '#4150JnSd1@#$%1...')
#2 [internal function]: ISPConfig_Create(Array, 'h1001', 'ZiJqJOsS3', 'h1001.test.su', '', Array, 'test@mail.ru')
#3 /var/www/clients/client2/web2/web/billing/hosts/hosting/system/classes/HostingServer.class.php(108): call_user_func_array('ISPConfig_Creat...', Array)
#4 [internal function]: HostingServer->Create('h1001', 'ZiJqJOsS3', 'h1001.test.su', '', Array, 'test@mail.ru')
#5 /var/www/clients/client2/web2/web/billing/core/Load.php(165) : eval()'d code(217): call_user_func_array(Array, Array)
#6 /var/www/clients/client2/web2/web/billing/core/Load.php(165): in /var/www/clients/client2/web2/web/billing/hosts/hosting/system/libs/ISPConfig.php on line 122
Ничё не работает
Сообщение Alex Keda » 2015-04-07 10:58:22
а что, своего почтового сервера нет?
какая разница какой email указывать-то?
ATaryanik
Сообщение ATaryanik » 2015-04-07 11:22:15
свой сервер отключен, если можно было бы настроить отсылку из внешнего smtp то было бы здорово.
Сообщение Alex Keda » 2015-04-07 11:38:01
это ошибка. чем меньше используется модулей, и вообще кода - тем выше вероятность что сообщение будет доставлено.
ATaryanik
Сообщение ATaryanik » 2015-04-07 11:43:54
ну что еще можно проверить без почты, какие логи еще?
могу любой доступ дать, мне уже самому интересно у вас работает у меня нет.
4-й день пошел...
alezhen
Благодарил (а): 5 раз
Сообщение alezhen » 2015-04-07 11:57:27
ATaryanik писал(а):Источник цитаты свой сервер отключен
как вы вообще собираетесь работать с биллингом без почты
Делайте следующее:
1) Чистим кеш на странице Дом
2) Удаляем файл debug.log
3) Активируем и потом выполняем задание на создание хостинг аккаунта в панели
4) Кидаем сюда содержимое debug.log
ATaryanik
Сообщение ATaryanik » 2015-04-07 12:27:24
Большой файл отладки
[11:17:16.05][48188] [JBs core]: запуск системы (2015-04-07)
[11:17:16.05][48188] [JBs core]: тип интерфейса сервера (cgi-fcgi)
[11:17:16.05][48188] [JBs core]: IP-адрес сервера (192.168.0.201)
[11:17:16.06][48188] [JBs core]: версия PHP интерпретатора (5.4.36-0+deb7u1)
[11:17:16.06][48188] [JBs core]: операционная система (Linux hosting46 3.2.0-4-686-pae #1 SMP Debian 3.2.65-1 i686)
[11:17:16.06][48188] [JBs core]: система запущена от имени пользователя (www-data)
[11:17:16.06][48188] [JBs core]: осуществлен запрос с адреса (31.200.199.91)
[11:17:16.06][48188] [JBs core]: REQUEST_URI=(/API/Events)
[11:17:16.06][48188] [JBs core]: HTTP_REFERER=(http://billing.hosting46.ru/Administrator/Tasks?Search=test@mail.ru&PatternOutID=Default)
[11:17:16.06][48188] [JBs core]: PATH=(:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/var/www/clients/client2/web2/web/billing:/var/www/clients/client2/web2/web:/var/www/clients/client2/web2)
[11:17:16.06][48188] [JBs core]: загрузка автозагружаемых классов и библиотек
[11:17:16.07][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/billing/system/libs/auto/Permission.php)
[11:17:16.07][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Args.php)
[11:17:16.07][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Arrays.php)
[11:17:16.07][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Cache.php)
[11:17:16.07][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Comp.php)
[11:17:16.07][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Config.php)
[11:17:16.07][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Crypt.php)
[11:17:16.07][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/DB.php)
[11:17:16.08][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/IO.php)
[11:17:16.08][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Links.php)
[11:17:16.08][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Messages.php)
[11:17:16.08][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Regulars.php)
[11:17:16.08][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Standard.php)
[11:17:16.08][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/String.php)
[11:17:16.08][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/Styles.php)
[11:17:16.09][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/System.php)
[11:17:16.09][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/auto/TemplateReplace.php)
[11:17:16.09][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/APCCache.class.php)
[11:17:16.09][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/Cache.class.php)
[11:17:16.09][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/CacheManager.class.php)
[11:17:16.09][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/Exception.class.php)
[11:17:16.09][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/JSmarty.class.php)
[11:17:16.10][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/MemcachedCache.class.php)
[11:17:16.10][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/MySQL.class.php)
[11:17:16.10][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/Smarty.class.php)
[11:17:16.10][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/Tag.class.php)
[11:17:16.10][48188] [JBs core]: загружается системный компонент (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/auto/jException.php)
[11:17:16.10][48188] [system/classes/auto/CacheManager.class.php]: Start initializing cache system.
[11:17:16.10][48188] [system/classes/auto/CacheManager.class.php]: Load APCCache
[11:17:16.10][48188] Initializing APC cache...
[11:17:16.11][48188] APC cache has been initialized.
[11:17:16.11][48188] Cache system has been initialized.
[11:17:16.11][48188] [JBs core]: внешний запрос сформирован как (__URI=/API/Events)
[11:17:16.11][48188] [JBs core]: загрузка автозагружаемых модулей
[11:17:16.11][48188] [JBs core]: загружается модуль (/var/www/clients/client2/web2/web/billing/hosts/billing/system/modules/auto/SetCookieSessionID.mod)
[11:17:16.12][48188] [JBs core]: загружается модуль (/var/www/clients/client2/web2/web/billing/hosts/billing/system/modules/auto/SetCookieOwner.mod)
[11:17:16.12][48188] [JBs core]: загружается модуль (/var/www/clients/client2/web2/web/billing/hosts/root/system/modules/auto/Security.mod)
[11:17:16.12][48188] [Security module]: [проверка Cookie]
[11:17:16.12][48188] [Security module]: (lang) = (ru)
[11:17:16.12][48188] [Security module]: (__cfduid) = (d46d4483f60ad760c11a0bc799344af4e1427875922)
[11:17:16.12][48188] [Security module]: (selected_language) = (Russian)
[11:17:16.12][48188] [Security module]: (PHPSESSID) = (51a9a9d3f2287ab90d1da47bad13401b)
[11:17:16.12][48188] [Security module]: (SessionID) = (SESSIONf899139df5e1059396431415e770c6dd55238292801d4)
[11:17:16.12][48188] [Security module]: (Email) = (admin@hosting46.ru)
[11:17:16.12][48188] [Security module]: (IsMobile) = (0)
[11:17:16.12][48188] [Security module]: (wScreen) = (1316)
[11:17:16.12][48188] [Security module]: (hScreen) = (619)
[11:17:16.12][48188] [Security module]: [проверка параметров]
[11:17:16.12][48188] [Security module]: (XMLHttpRequest) = (yes)
[11:17:16.12][48188] [Security module]: проверка параметров реферера для REQUEST_URI = /API/Events
[11:17:16.13][48188] [JBs core]: загружается модуль (/var/www/clients/client2/web2/web/billing/hosts/root/system/modules/auto/Redirects.mod)
[11:17:16.13][48188] [JBs core]: загружается модуль (/var/www/clients/client2/web2/web/billing/hosts/root/system/modules/auto/Request.mod)
[11:17:16.13][48188] [Request module]: [замена параметров]
[11:17:16.13][48188] [System_Load]: компонент системы (/var/www/clients/client2/web2/web/billing/hosts/root/system/classes/Session.class.php) был загружен
[11:17:16.14][48188] [IO_Read]: открытие файла (/var/www/clients/client2/web2/web/billing/hosts/billing.hosting46.ru/tmp/sessions/SESSIONf899139df5e1059396431415e770c6dd55238292801d4)
[11:17:16.14][48188] Load file: '/var/www/clients/client2/web2/web/billing/hosts/billing/comp/Users/Init.comp.php'
[11:17:16.14][48188] [System_Load]: компонент системы (/var/www/clients/client2/web2/web/billing/hosts/root/system/libs/Tree.php) был загружен
[11:17:16.15][48188] [MySQL->Open]: связь как (jbs@localhost:3306) установлена
[11:17:16.15][48188] [MySQL->Query]: SET NAMES `utf8`
[11:17:16.15][48188] [MySQL->Query]: USE `jbs`
[11:17:16.15][48188] [MySQL->Query]: SELECT `ID`,`GroupID`,`Name`,`Sign`,`Email`,`EmailConfirmed`,`MobileConfirmed`,`ICQ`,`JabberID`,`Mobile`,`UniqID`,`Params`,`LayPayMaxSumm`,`LayPayThreshold`,`EnterIP`,`EnterDate` FROM `Users` WHERE `ID` = 100
[11:17:16.16][48188] [MySQL->Query]: SELECT * FROM `Permissions` WHERE ('/API/Events' LIKE `Name`) ORDER BY `Metric`
[11:17:16.16][48188] Load file: '/var/www/clients/client2/web2/web/billing/hosts/root/comp/Formats/Explode/Logic.comp.php'
[11:17:16.17][48188] [MySQL->Query]: SELECT `ID`,`GroupID` FROM `Users` WHERE `ID` = 100
[11:17:16.17][48188] [MySQL->Query]: SELECT `ID`,`GroupID`,`OwnerID`,`IsManaged` FROM `Users` WHERE `ID` = 1
[11:17:16.17][48188] Load file: '/var/www/clients/client2/web2/web/billing/hosts/root/comp/Formats/Explode/Logic.comp.php'
[11:17:16.18][48188] [MySQL->Query]: SET @local.__USER_ID = 100
[11:17:16.18][48188] [MySQL->Query]: SET @local.__USER_GROUPS_PATH = '1,3000000'
[11:17:16.18][48188] [MySQL->Query]: SET @local.__USER_GROUPS_ENTRANCE = '3000000,3100000,3200000,3300000,3900000'
[11:17:16.18][48188] [IO_Read]: открытие файла (/var/www/clients/client2/web2/web/billing/hosts/billing.hosting46.ru/tmp/sessions/SESSIONf899139df5e1059396431415e770c6dd55238292801d4)
[11:17:16.19][48188] [MySQL->Query]: UPDATE `Users` SET `EnterDate` = '1428394636',`EnterIP` = '31.200.199.91' WHERE `ID` = 100
[11:17:16.24][48188] [MySQL->Query]: SELECT * FROM `Permissions` WHERE ('/Administrator/' LIKE `Name`) ORDER BY `Metric`
[11:17:16.24][48188] Load file: '/var/www/clients/client2/web2/web/billing/hosts/root/comp/Formats/Explode/Logic.comp.php'
[11:17:16.25][48188] Load file: '/var/www/clients/client2/web2/web/billing/hosts/root/comp/Formats/Explode/Logic.comp.php'
[11:17:16.25][48188] [MySQL->Query]: SELECT `ID`,`GroupID` FROM `Users` WHERE `ID` = 100
[11:17:16.26][48188] [MySQL->Query]: SELECT `ID`,`GroupID`,`OwnerID`,`IsManaged` FROM `Users` WHERE `ID` = 1
[11:17:16.26][48188] Load file: '/var/www/clients/client2/web2/web/billing/hosts/root/comp/Formats/Explode/Logic.comp.php'
[11:17:16.27][48188] Load file: '/var/www/clients/client2/web2/web/billing/hosts/billing/comp/www/API/Events.comp.php'
[11:17:16.27][48188] [System_Load]: компонент системы (/var/www/clients/client2/web2/web/billing/hosts/billing/system/modules/Authorisation.mod) был загружен
[11:17:16.27][48188] [comp/www/API/Events]: UserID: 100, результат найден в кэше
[11:17:16.27][48188] [JBs core]: система работала: 0.2214720249176
[11:17:16.27][48188] [JBs core]: время работы MySQL: 0.056989669799805 [25.73%]
[11:17:16.27][48188] [JBs core]: запросов к MySQL: 11
[11:17:16.27][48188] [JBs core]: загружено компонентов: 8
и еще в догонку от крона
alezhen
Сообщение alezhen » 2015-04-07 13:56:57
У Вас в логах нет никаких ошибок касательно панели. Вернее ошибок нет вообще.
