Ошибка выполнения (100)
nailfox
Сообщение nailfox » 2014-11-18 14:50:10
Всем привет!
Все как год отработало отлично, никаких нареканий не было. И тут решили добавить новую услугу. В Настройке услуг нажимаю Новая услуга, и на тебе Ошибка выполнения (100).
Смотрю лог
[02:38:10.61][6318] [String_XML_Parse]: парсирование строки (278 bytes)
[02:38:10.61][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/billing/comp/Triggers/DOM/Before/Base.comp.php'
[02:38:10.61][6318] [MySQL->Query]: SELECT `Value` FROM `Config` WHERE (`Param` = 'Copyright')
[02:38:10.62][6318] [APCCache::get]: не удалось извлечь объект [key=System_HostsIDs[f214d349d5f2aa0cf4b85e3bfaa1ed15]]
[02:38:10.62][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/billing/comp/Form/Owner.comp.php'
[02:38:10.62][6318] [MySQL->Query]: SELECT `ID`,`Name` FROM `Groups`
[02:38:10.63][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Select.comp.php'
[02:38:10.64][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Input.comp.php'
[02:38:10.64][6318] [APCCache::get]: не удалось извлечь объект [key=System_HostsIDs[3bc7e7269732de5f11869aa44da23b47]]
[02:38:10.64][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/billing/comp/Users/Select.comp.php'
[02:38:10.65][6318] [MySQL->Query]: SELECT `ID`,`GroupID`,`Email`,`Name` FROM `Users` WHERE `ID` = 1
[02:38:10.65][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Input.comp.php'
[02:38:10.66][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Prompt.comp.php'
[02:38:10.66][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Css.comp.php'
[02:38:10.67][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Input.comp.php'
[02:38:10.67][6318] [MySQL->Query]: SELECT `ID`,`Name` FROM `ServicesGroups`
[02:38:10.67][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Select.comp.php'
[02:38:10.68][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Input.comp.php'
[02:38:10.68][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Prompt.comp.php'
[02:38:10.69][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Prompt.comp.php'
[02:38:10.69][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Input.comp.php'
[02:38:10.70][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Prompt.comp.php'
[02:38:10.70][6318] [APCCache::get]: не удалось извлечь объект [key=System_HostsIDs[990302db03297b1faee81475f7403ab7]]
[02:38:10.70][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Upload.comp.php'
[02:38:10.70][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Css.comp.php'
[02:38:10.70][6318] [APCCache::get]: не удалось извлечь объект [key=System_HostsIDs[5564269c7ac88ca1543f34b5ef8da378]]
[02:38:10.70][6318] [IO_Read]: открытие файла (/opt/bitnami/apache2/htdocs/hosts/root/templates/modules/Upload.DIV.html)
[02:38:10.70][6318] [String_XML_Parse]: парсирование строки (752 bytes)
[02:38:10.71][6318] [APCCache::get]: не удалось извлечь объект [key=System_HostsIDs[eb8dba2638cda0fd33cc7b89b3a3f5c1]]
[02:38:10.71][6318] [IO_Read]: открытие файла (/opt/bitnami/apache2/htdocs/hosts/root/templates/modules/Upload.Button.html)
[02:38:10.71][6318] [String_XML_Parse]: парсирование строки (297 bytes)
[02:38:10.71][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Input.comp.php'
[02:38:10.71][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/root/comp/Form/Select.comp.php'
[02:38:10.71][6318] [APCCache::get]: не удалось извлечь объект [key=System_HostsIDs[c1e37867483e8083de835a148f0a0a5f]]
[02:38:10.71][6318] Load file: '/opt/bitnami/apache2/htdocs/hosts/billing/comp/Form/Summ.comp.php'
[02:38:10.72][6318] [!] [!!8]-Undefined index: PartnersRewardPercent в линии 457 файла /opt/bitnami/apache2/htdocs/core/Load.php(154) : eval()'d code
В какую сторону копать? Если надо больше лога, могу дать больше лога)
Последний раз редактировалось Alex Keda 2014-11-19 20:19:01, всего редактировалось 1 раз.
Re: Ошибка выполнения (100)
Сообщение Alex Keda » 2014-11-18 18:56:15
как-то криво обновились чтоле...
не до конца, например.
в таком сучае, лучше обновить до конца - всё само пофиксится
или же
1. проверьте наличие колонки PartnersRewardPercent в таблице Services
2. проверьте её же наличие во вьюхе ServicesOwners
в первом случае - аккуратненько добавить, как в файлике patches/hosting/db/1000288.sql
во втором, заново создать все вьюхи:
mysql billing_db < db/billing/views.sql
nailfox
Сообщение nailfox » 2014-11-18 22:36:13
Как повторно выполнить обновление? Или только ручками?
Сообщение Alex Keda » 2014-11-19 10:24:12
как и всегда - кнопочки в интерфейсе понажимать и всё....
nailfox
Сообщение nailfox » 2014-11-19 13:18:20
Пробовал еще раз обновить - тот же результат. Ради эксперимента скачал дистр новый (27), так же ошибка 100. Ставлю старые версии Joonte, все гуд.
nailfox
Сообщение nailfox » 2014-11-19 13:54:45
В общем, работает корректно только версия 24. Никаких требований не менялось для работы системы, начиная с 25 версии?
Сообщение Alex Keda » 2014-11-19 15:14:40
вы со старой базой чтоли пробовали новые дистры?
ничё что структура базы при обновлениях тоже может меняться?
и вы так ничего и не сказали насчёт наличия/отсутствия указанной колонки в БД
nailfox
Сообщение nailfox » 2014-11-19 15:31:06
С колонками все ок. Новые дистры ставлю на новую чистую базу, я в курсе, что структура может меняться)))
Сообщение Alex Keda » 2014-11-19 20:18:45
поправил. прогоните ещё раз процедуру обновления
nailfox
Сообщение nailfox » 2014-11-19 23:05:26
Все гуд, спасибо)
